... ... ... ..... This is incorrect for a toy hauler... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... .....
If you had written, "I disagree" I would have simply ignored your post. But since you wrote "this is incorrect" I will explain, for the benefit of others who might read this and make decisions based on it, why my post was not "incorrect. "
I have visited several RV manufacturing plants over the years since the early '70s. None I have toured have an actual scale for weighing their products. The empty weight of a particular model provided by RV manufacturers is at best an engineer's calculated or estimated theoretical weight. At worst, it is influenced by marketing reasons and is deliberately lower than actual shipping weight. It is never/very rarely accurate because it is based on a unit with no options. It is safer to assume that every trailer is delivered weighing more than the dry weight listed in brochures.
Assuming the trailer actually weighs more than the manufacturer's stated weight then adding one air conditioner, two television sets, a generator, and various other options or accessories like gas tanks and electric pumps, additional batteries, and a spare tire and wheel would probably easily add 1,000 to 1,500 lbs.
Then, when you fill the propane tanks and water tank, add food (canned, packaged and refrigerated), clothing, bedding, and personal items to the living compartment an additional 1,000 lbs. to 1,500 lbs. or more has been added.
I have no idea how the original poster would use his toy hauler but if his family has several quads and/or motorcycles weighing 600-700 lbs. each that is likely to be another 2,000 to 3,000 lbs. added.
Toyhaulers I have pulled have gasoline tanks and electric transfer pumps, hoses, and a nozzle. Gasoline weighs what, 5-6 lbs. per gallon? I never paid any attention to the size of toyhauler gas tanks but assuming the tank is at least 20 gallons the tank, gasoline, transfer pump, hardware and plumbing would add another 200-300 lbs.
Folks who use toyhaulers and haul their toys to the desert carry tools, helmets, safety equipment and clothing, possibly spare parts, and various other items. I would estimate another 500 to 1,000 lbs.
I'm not going to add the weight of the items I listed because they are only educated guesses or estimates but as I said, dry weights are best placed in the "wishful thinking" column. Experienced RVers know that the GVWR of any unit is likely to be a very good estimate of it's traveling weight.
I weighed my own Hitchhiker 5er recently. The manufacturer said its dry weight was something like 12,500# and king pin weight something like 2,500#. With only modest loading it scaled 14,000 lbs. and the kingpin weight was 3,600#. It has two ac units, one over the front bedroom, and an Onan 5. 5KW generator, neither of which are included in the dry weight.
Each to his own. If someone decides to pull such a trailer it is not my concern. My only interest is in providing answers I believe to be accurate and correct when someone asks a question.
Harvey
