Michigan law, section 257. 710c subsection(4) says that coil spring spacers are prohibited. I does not say wether they are talking about the actual spacers that twist into springs or a spacedr that bolts into the frame to lower the spring pocket itself. I myself would never write anyone for a dodge coil spring drop spacer that was a manufactured kit piece. A hacked looking homemade job yes, but not a lift kit piece from a reputable company. Also, lift blocks between leaf springs and the front axle are prohibited, and no more than a 4" block in the rear, in conmjunction with the factory block if so ecquipped.
Bumper height 7,501-10,000 lbs gvwr is 26 inches to bottom and fram 30 inches to bottom midway between front and 2nd axles
