Can I directly swap ISSPRO for Autometer boost gauge?
Best source for 12 volt ignition power for gauges
Howdy all,
I currently have the ISSPRO 0-30 # boost gauge, and would like to get the new Autometer Ultra-Lite 0-60# gauge. I just discovered that ISSPRO also makes a 0-50# gauge. My question is: Does anyone know if I can simply remove only my ISSPRO and directly replace it with the new Autometer gauge with no other things having to be replaced?
Thanks,
Tom
Tom Golden
Godzilla: Patriot Blue 2001 2500 SLT QC 4X4 LWB ETH/DEE, Tow & Camper packages, 3. 54 Ltd. Slip, 4 wheel disc ABS, Isspro EGT/boost gauges, black SmittyBilt nerf bars, K&N RE-0880 & pre-filter, no silencer ring, TDR decal, Jack holiday antenna ball
NRA Life/CRPA/El Dorado #26 F. &A. M. of California
If the line size is the same size, which it should be, you can swap gauges without any problems as long as the gauge diameter size is the same for mounting in your pillar.
