I have a 3500 SRW that I use quite a bit (111K miles in 22 months). I usually run at near the 9900 VWR or completely empty, not much in between. I notice this truck sags quite a bit more than my Y2K 2500 did. This makes for a nice unladen ride but a very low bumper with a good load. I currently have timberens on the truck, but they quickly become the suspension system to themselves whenb loaded. If I put 500 LBs or 2500 LBs on the bumper or the goose neck pin, I can not make the overloads touch with the timberens installed. I called them and they sent lighter springs, but they still will not allow the overloads to contact.
I am looking at two ways to eliminate the timbrens and keep the rear bumper off the ground. #1 I am thinks of moving the axle spacers like many have. Instead of putting both spacers on top of the axle in the storage position, I intend to put one in between the regular and the overloads. This will put the overloads 3/4 inch closer to contacting from the start. Will this work? I am looking for feed back from some who have already moved the spacers.
Option two would be to look for longer bump stops that would contact the overload springs sooner. I thought that I had read on here about some longer stops from Energy Suspension. I have done many searches under all the possibe names that I could think of and came up empty. Any feed back on this?
Either way I am going to have a set of Timbrens with two differents sets of springs for sale.
