can i run wheel/tires with no tpms sensor?
Buying 2019 RAM 3500 DRW - discount expectations?
Engine Brake and the Turbo
thanks to everyone for the info. went with some mopar sensors. will install next week or so. this week we had zero and snow for denver area. the wait at the tire shops was 1 - 2 days to get anything done. never seen them so busy. cheers all!
comrades! installed duratracks with the mopar sensors that TC recommended. everything perfect. for some reason, getting any tire balanced is an issue in denver. took 3 tries at 2 different tire shops to get the job done right.... which is par for the course the older that i get. somehow EVERYTHING is a pain in the a$% :) cheers!
No one has mentioned that a tire dealer cant legally send you on the road without the required safety equipment.
If you are installing own theres you'll be fine, but if you go to a pro to have tires installed, they won't do it without the sensors.
I picked up a 2019 3500 yesterday. I'll be buying these sensors for whatever 18" rims I get to replace the 20" firestones it came with.
Thanks for the link TCD!
