Originally posted by Deezul 1
Ok I am learning something here. I have always known dont flat tow an auto trans without removing the driveshaft but on a 5 speed?
The inner bearings of the transmission are lubricated by the front idler geartrain pumping oil up into the direct through cluster. As long as your front gears are turning (engine running, clutch engaged), these bearings get oil. They do NOT get oil if you are in neutral and the engine off. Of course, there's a little in there ,and you can go a short distance from the lubricant already there, but not very far.
What will happen, is that as soon as the lube gets thin things will start to heat up, and as soon as they get hot enough, the main shafts through the transmission will seize together. I've even heard of the transmission getting so hot that it caught fire while the truck was being towed.
It doesn't take long, especially if the truck sat for a long time before being moved, and the lube has all drained away. Damage could occurr within a few hundred feet, in that case.
The Getrag, NV4500, NV5600 and lots of other modern transmissions are all the same. For that matter, most throughout history have been pretty much that way, but with historical use of heavy greases and extra idling gears driven off the output, some trannies had no problem being towed in neutral.
