Originally posted by mark93
In the exploded view of the NP 205 transfer case I see no oil pump.
Some aluminum case units, like the 208, 231 and 241, do have an oil pump.
The 205 would suffer the same as a manual trans because there are no gears turning in neutral.
Before 1966 they used to put rear pumps in auto transmissions so you could push start the car and tow without restictions when the trans was in neutral. I read somewhere the rear pump was eliminated for "safety reasons" (it's safe to say profit was increased). Speaking of increased profit, it reminds me of the 6 speed second gens getting a 13" clutch the Mickey Mouse way-all those baloney modifications to the starter mount, flywheel and clutch cover to get a clutch inferior the first gens!
No, there is no "pump" if you're looking for an engine oil pump type pump. What happens, is that the rotation of the front gears and the design of the case lifts oil out of the bottom of the transmission and spreads it across the upper gear shafts, lubricating the bearings. IN all probability (I haven't seen the innards of a Getrag or NV 4500 ), the oil is flung up, and some small "catcher" will direct it into a bearing and through the shaft to lubricate the rest of the inner bearings.
In a transfer case, there is a large gear attached to the output shaft that does the same thing. By the operation of this gear, and passages and blocks built into the housing and shafts, the output shaft functions as the "oil pump" in the same way, by tranferring oil into the inner bearings when the vehicle moves.
Even transmission guys refer to it as "the pump" because it's action is to move oil up and funnel it into the critical bearings.
