Details here: TDR Privileges
I thought my TC was going bad, but looking and OEM manual there is an overdrive clutch. Since my truck slips a lot under load in 4th gear, could it be OD is the problem ?
You might be able to tell if it's the TC or one of the other clutches. Watch the tachometer when it slips, you should not see more than about 500 rpm rise in engine speed if it is the TC. bg
