Can someone identify this Holset turbo?
A question to all BD pressure lock users
TST and high Idle feature question
On the truck I recently purchased is a rather strange looking turbo. Every time I pop the hood to give someone a looksee, they all say the same thing: "that ain't the stock turbo is it?".
Here's a pic of the dataplate. No pics of the turbo itself. Compressor side is black, turbine side is rust just like all others. Truck is a manual trans.
In case you can't read it, the tag is as follows:
Assy. 3533320
Serial: C0296353
Customer: 3925740-0-09/3
Type WH1C
Thanks,
Andy
Nebbermind... . It appears that this is the turbo used on the 1994's. I thought they were all HX's or HY-35's. Evidently first 12v's had the WH1C.
I guess that settles that. :)
Thanks,
Andy
The WH1C uses the same exhause housings as the HX35's. If it's wastegated it's most likely a 12. The earlier (1st gens) came with bigger non-wastegated housings.
The WH1C and early hx35 was basically the same performance wise.
The difference is that the WH1C uses a band clamp around the compressor housing instead of the snap ring that the HX uses. Cost cutting...
