Was changing motor oil in one of my 03's. Noticed half of my starter (back half) is covered in diesel fuel. Looks line the supply line coming from inside the frame rail (underneath the drivers seat) to the fuel filter is leaking. Can I just cut out the steel line and replace it with a rubber fuel line? Also, the fuel lines going to the injector pump look real bad, (thanks to all of Jersey's road salt!!!). I was thinking of purchasing the GDP'S 2 mic. under the hood fuel filter kit and those lines are all rubber, will they replace the stock steel lines going to the injector pump? Thanks for any help. Frank
