I don't know what the amp load of the PIAA lights is but it will not put more load on the switch as the lights are run through the relay in the PDC. If the load is too high then use of the relay as sugested above with a seperate power supply would solve the problem. bgOriginally posted by BigDan
Pretty much sums it up. Since I just bought a new headlight switch and would rather not run the factory PIAA switch. That and will the factory harness be able to handle the 510's it I just plug in the 510's at the factory harness in the bumper.
Originally posted by B. G. Smith
I don't know what the amp load of the PIAA lights is but it will not put more load on the switch as the lights are run through the relay in the PDC . . .
