I have a small engine oil leak from the left front. It is so minimal that no oil is needed between changes (around 10 -15k miles).
I guess it has been leaking quite some time. The crank position sensor was so gummed up it was barely recognisably.
I thought the pan gasket was leaking so I tried to tighten the bolts, but none were really loose.
Any ideas to what may be the source? I did have the Dodge dealer replace the water pump in 3/10. It could have been leaking since then, but where?
thanks, Ron
thanks, Ron
