JKosten
I have been having a wondering issue with my steering than has progressively been getting worse.
My first steps to diagnoses was to check that all suspension parts are torqued and lubricated. After that I looked for unusual signs of wear or contact. When than did not reveal anything I started to research and ask around. The wondering was causing constant correction while on the highway and the steering felt tighter than it did when new. I almost replaced the P/S pump (so many have said it helped), but it is still on my parts self. The signs pointed at failed ball joints, but I have Carli Ball joints that are about 3 yrs old with maybe 40k -50k miles on them (maybe). So like I said earlier, everything on the suspension took grease and gets greased regularly.
Then looking at how the ball joints work the lower joints use a ball and cup, where as the uppers (Carli) uses a pin and housing. I have heard of them being machined very tight on tolerances and having a coating to help maintain lubricity. The upper pins could cause binding in the knuckle and create tighter steering.
I decided to pull my uppers a part to inspect the pins and replace all the grease inside them.
The results of disassemble, cleaning and reinstalation are remarkable and disturbing at the same time. The pins were worn unevenly, grease had failed, and the shafts were almost galled were the grease was displaced.
First step: lift and support one side of the front axle. Them remove the tire.
Next gather up a 7/16" wrench (ratcheting) 15/16" wrench and a 1-1/4" socket or wrench.
Then clean and remove the top cap with the 1-1/4" and clean away grease to reveal the pin. The grease should be red (not black)
Next use the 7/16 to hold the pin and the 15/16 to loosen the main nut.
Once the nut is removed lift up and wiggle the hub, the pin will pop up ward.
Now inspect and clean.
See the wear?
See page 2 (5 images per post?)
See the wear?
