When I tried to adjust the caster on my '97 4x4, I found that the bolt that turns the eccentric plates is frozen in the leading arm sleeve.
Does any body have suggestions on how to get this loose? On one hand, I'm tempted to heat the threaded end of the bolt with an acetylene torch, the worst it can do is screw up the rubber bushing assy ... which is already screwed up!
Can I buy a new leading arm rubber bushing with the steel sleeve in it? If I have to replace the leading arm, are there better sources than Dodge?
Help will be appreciated!
