Kevin,
I'm not able to understand which ECM of those I have here is yours.
I've contacted Doug but have not yet heard back from him. I will contact you ASAP.
It could be that you've got the wrong file for your truck but only if you provided a wrong describtion of your truck...
Your truck is a 2001. 5 ( with rear discs??) Automatic, Federal or Carb?
For the "incompatibility" of the CaTCHER with the Comp. That has to do with the HP gain at high Rpm, certainly not with limp mode. Limp mode you shouldn't get! Are you SURE that your problem is not Comp related?
Code # 237 is MAP sensor voltage too low. The Comp plays with the MAP sensor signal, not the ECM... .
Let me know if I can help you!
Marco
Marco
