To go along with my 2m Ham radio in my truck I also have a Texas Ranger CB. I just installed it in the truck. Normally when you key the mic you will see the power meter needle rise (move to the right) to the output wattage of the radio, then see the needle modulate as you talk. When I key the mike the needle moves all the way to the left and does not modulate as I talk.
I had the radio in my other truck and it worked fine. I checked to make sure it was not a problem in the mic by haveing a friend try it in his truck and it checked out OK.
So where should I go now? And Ideas on what to check next?
Thank you,
Jason
Thank you,
Jason
