TSkoropad
Greetings folks,
Been a member here since August, obviously lurking. Now I’m looking for some advice from the Cummins gurus.
Brief history of the truck
Purchased new in August of 2011, now at 32200km.
Installed S&B Filters cold air kit w/scoop, and MBRP dual cat back system in June of 2012.
No other performance mods.
Everything was great until this past spring. Took the vehicle in for the tie rod recall, and was told that there was an additional recall, namely the transmission harness overlay or O2 sensor harness recall.
The aforementioned recall was completed and this October the check engine light came on. Returned to dealer for service, to find that codes P2626, P2195, and P241A were logged. Both O2 sensors were found to be sooted and uncleanable, and the O2 module had an internal circuit failure. All three were replaced and the harness and connectors were checked for corrosion.
Codes cleared vehicle test driven for 100km or so and deemed repaired.
Now yesterday, less than 1000km later the check engine light came back on. Returned to dealer, and managed an appointment for this morning. Final diagnosis, same codes logged as previously. Technician checked all previous work, harness, connectors, etc. and stated all appeared okay. Codes once again cleared, and vehicle returned.
Service writer stated that the possible cause was the fact that I had modified the vehicle with the cold air kit and that the engine was receiving too much air, thus logging the fault codes. He also stated the next step if the CEL reappears, would be to contact Chrysler tech, but that as soon as they found out about the cold air kit, they would refuse tech support or any warranty service.
My feeling... I believe I was being fed a load of “bovine scat.”
I did contact S&B and spoke with their tech person to see if they’ve had report of this issue. He advised never. He did have me send him the previous dealer work orders, and advised he would have his top tech guy contact my dealer’s service department to discuss the situation. Awaiting the result as I write this.
Looking for thoughts and insight from the folks here.
