Cha;nge light color of gauges?
more thermocouple ?
Skyjacker suspension
I remember reading some time ago about how to change the light color in gauges, however, I have not been able to find the info through searching. I purchased VDO Vision Series gauges for the truck. Design is the same, but the color is white and not green as compared to the instrument panel. Could someone give me some help? Thanks.
2001 Ram 3500 dually, 4:10, auto, SLT+,anti-spin,custom side paint(parchment/cabernet red), Custom pin striping,Advanced Thermal Products Sound Blanket Kit, Smittybar nerf step,Geno's stainless wheel well trim, tonneau cover, air dam, chrome monster tip, mud flaps/chrome tips,pyro-trans-boost gauges, Bosch 275 Injectors
Most auto parts stores have little covers that go over the bulbs, green , red , blue, and others.
Auto Zone here has them.
99 3500 QC, white, 5sp, 3. 55lsd, isspro EGT & boost, stock, 36,500 miles 05-05-00- (EX phord owner) 15-16. 5 MPG hwy ,14-15 city , 10-12 with 4,000lb TT , 1500 - 3000 in 4th = 13 sec
(added VA 2/16/00)1500- 3000 in 4th = 10 sec
removed VA , put in 275 1500 - 3000 4th = 11. 15 sec , slight mpg increase both ways.
Friend borrowed VA , now I need another.
I have Westach gauges and an autometer gauge in my truck. Both came with a colored transparent boot (condom) to put over the light bulb. I have no idea where you would be able to find one though.
Arlan
Millfly-
I just got my VDO Vision gauges and the Boost and Oil Temp came with little colored condoms to slip over the white lamps to change the color. The green is a perfect match! As far as the pyro, it has a smaller lamp with no color change provisions. I just painted the little lamp green and it looks like the others.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, etc.
"Diesel, it's not just for breakfast!"
I will have to check out thos colored filters from autozone. My Isspro boost gauge is white but so dim you can hardly see it.
-- Keith Wing
'98 2500HD SLT QC Long Bed, 5 speed, 4. 10 (Sur Grip), ISB Cummins (TST/Injectors), 42 psi boost, Spray in Bed Liner, Toolbox, 255/85 Mud Rovers, Grizzly Brush Guard, Green, Trailer Tow Package, Camper Special, Remote Start
Operating Weight: 7,500 lbs
45-80 in 5th: 6 seconds
The gauges usually use a #194 bulb. These are available in a couple of colors. Also Ive seen the boots advertised in speed catalogs.
1999 2500 Cummins w/4spd auto,3. 54s,Quad Cab,SWB,4x4,Flame red ,all options less leather and radio controls on steering wheel,OEM color matched runningboards,DeeZee bedrails painted black,Power Vision Mirrors,OEM ventshades,Oem sill covers,OEM underrail bedliner,Isspro pyro,Westach temp,Painless wiring,RadioShack CB,Westin Black brushguard
The bulbs for the ISSPRO cum in at least 3 different wattages, the stock ones that came with my guages were the lowest wattage. I tried the next higher, a little better , then got the highest watt and it works good. Sorry ,Not sure of the bulb numbers.
Millfly,
I think you were shorted the bulb condoms, all of my VDO Vision guages, including the pyro, came with green and orange condoms.
'95 2500, SLT, 4x4, 5-Speed, 4. 10 LSD, TST #6 250/635, VDO EGT-Oil-Trans temp on A-pillar, Isspro Boost, Mag-Hytec, Amsoil in dif's & engine, Leer shell, Bushwacker flares, 33x12. 50 on Weld 16. 5x9. 75 --19Kmi
Thanks for all the advice! I am going to call the garage that installed the gauges and ask what happened to the bulb covers. If that does not work out I will go to the local Penn Jersey Auto Store and check it out with them. Thanks for all the help.
