Change input or output shafts
Banks Exhaust Brake
Fuel Pressure & General Gauge Qestion
Im looking for about 450 hp(TST comp, 100hp injectors, bigger turbo than the HY, DTT TC and VB and smart controler) maybe alittle less but around that. What shaft should i change? Do i even need to change it? Are they hard to change? Thanks for the input!
Both, the input is easier because you need a press to take the OD unit apart.
If you dont do 4x4launches, or use a lockup switch you may not need either. But its a good idea.
