Change NV271 Transfer Case Oil
Which clutch?
fuel milage drop
My truck is coming up on 25k miles. That being said, I have been reading post on how-to change the oil in the differentials and the NV5600; however the one item I have not been able to find much detail on, is rather or not the transfer case and NV5600 share the same oil or not. I think I remember reading somewhere that they are separated by seals and the transfer case takes ATF? Any links comments are welcome. Thanks in advance
Note: I am not sure if it matters or not, but I have the electronically shifted transfer case.
The two components are seperate! ATF+4 in Xfr case, 10W-30 in the
NV-5600. I use the Amsoil lubes, of course.
Wayne
amsoilman
I've read this 10w-30 thing which brings up another thing ... ... ... . it this detergent or non-detergent? I would assume non-detergent since there is no combustion involved?
This thread reminded me on my next oil/filter to do the transfer case too. As I was looking over the service manual for the change procedure I noticed on page 21-646 there's a magnet in the transfer case. Unfortunately you have to disassemble the case to get to it! That stinks!!
It would be *nice* if an enterprising young machinist were to offer a replacement drain plug with a very strong magnet on it. ;)
-Ryan
I have been running light synthetic motor oil (Mobile One) in my transfere case for as long as I have had my Dodge. I checked with the manufacturer of the TCase and an engineer told me that ATF is really too thin and recommended light sythetic for best service. I have Auto transmission, the two are separate, there is seal and leak area between mine. I have replaced the rear seal on the transmission myself. Just my 2 cents worth.
Thanks for the replies everyone. I plan on replacing with OEM spec fluids. If ATF comes out of the transfer case then ATF is going back in. I also plan on using Pennzoil synchromesh fluid for the NV5600 and 75-90w syth for the differentials.
my truck is 100% stock (except for the break controller and the fuzzy dice hanging from rear-view mirror) My goal is to keep it that way until the warranty is up (since I paid for it) Then I will worry about bombing the hell out of it.
It is a good idea to at least look at the t-case fluid. My '99 Ford was turning it black (ATF). After a couple of changes at the 5k oil interval I swapped it to Amsoil ATF and it never turned dark again. I started changing all of my t-cases when the transmission flushes are done, and they all run synthetic ATF now.
IIRC, the other two 4x4s I have owned both used ATF in the transfer case. One was a Ford Bronco II the other was a Mazda B4000 (Ranger). Both had Borg-Warner cases. My point is it doesn't seem to be uncommon for t-cases to take ATF. However, I've always thought it was dumb and that the cases should take the same fluid as a manual transmission. But I'm afraid to use anything else... although KB0OU gives me a little more faith. Wayne, I'm surprised you're using ATF... I would've thought if there were a "better" fluid type you'd be using it (you're usually pretty saavy with your fluids). So why aren't you using something like 10w-30 in the t-case too?
-Ryan
Any of the fluids in the transmission or transfer case is detergent, as they are using synthetic lubes, which are highly detergent.
Wayne
amsoilman
-Ryan
The transfer case calls for ATF as the lubricant, which I do use.
Wayne
amsoilman
