Change tire and rim size?
New Truck order needs to be changed ASAP
Clearance Light Install - Juice where?
I need higher load capacity tires than my stock 265/17 Michelin LTX AS. Can I change out my rims and tires and go to a 265 or 285 16 without screwing everything up. I'm thinking if I keep the approximate same diameter as stock I should be OK. Of course I'm not a math genius so I'm guessing.
The tire selection and load capacity for the 16's is much better than 17's. I would like to get up around 3750 # per tire. I have looked at the Toyo but they are very $$ in 17's
Any info or help would be appreciated.
Cliff
I just had the 285 Toyo AT's installed on my truck and so far I really like them. Main reason I changed out was the stock Michelin's just sucked in the snow and ice. I thought about the Rickson route but I can mount four sets of Toyos for the price of the Rickson wheels and tires.
