GAmes, We agree on much more that we disagree.. I have validated first hand that you are 100% correct on the RV trailers being built with the cheapest components possible, at this point I'm just about 100% rebuilt on mine and have seen the cheapness first hand. Tires are garbage, brakes are marginal... mine developed an internal short in the axle tube, I had to 100% re-wire, and the original wire was not adequate for the current demands of electric brakes.. I really considered going with the hydraulic disc brakes at the time. Now having a broken spring of all things, but this seems to clearly be related to odd shaped tire, so at least I should not have to think broken springs are that common, just the same I increased the capacity of the spring for all 4 while at it and will replace all the hardware, and add shocks.
I guess I should add, by axle capacity, my rig is no where close to what it is rated for, and I'm convinced now that one needs a large buffer where components are rated well ABOVE typical loads..
When I first got the trailer, I hauled it with a 1/2 ton gas pick-up, and with that rig, 60MPH was the fastest speed, in some cases most it could do period, but from a safety perspective the truck and trailer were of similar weights, making it much less stable..
That said, now I tow with a 3500 Dodge, long bed, crew cab.. it is VERY stable.. I have to check to make sure it has not come off, because it is so well under what the truck can tow it is not even 1/3.. with this particular rig I can get up to 70 -75 and be very stable, I rarely even notice a cross-wind, nor have any sway at all, I've tried to induce it to be sure, I can swerve and it goes as straight as an arrow, no issues.. the point we all need to realize is that each combination of tow vehicle and trailer and loading pattern will have considerable effects on stability and safe tow speed, the prudent and safe driver will diligently assess this for their particular rig. There is no one size fits all safe speed for all combinations of trailers.
And yes, I'm aware of the California limits, and I've often done 62 going through, but get tired of constantly being passed by 18wheelers.. so I adjust accordingly, most rigs seem to do about 65-67 in Cali.
Having said all that, whenever possible, and not in a tight schedule, I've come to prefer US roads and back roads where speeds are closer to 55-60 MPH, the views are better, less stress in most cases, better things to see.. but can't always do this, and as you correctly point out, much, much better MPG, in mine it is from about 11 to about 14, and as a percentage, that is HUGE.
