Engine/Transmission (1998.5 - 2002) changed filter now engine wont crank
2nd Gen Non-Engine/Transmission Rancho 9000X shocks
I changed the fuel filter in my 01' dodge cummins now engine wont crank . Lift pump is new could my injector pump have gone bad . I am not hearing the buzz the inj. pump usually makes when I turn thekey
The lift pump is the one that buzzes Just bump the starter then youll hear the buzzing start, after it stops buzzing bump the starter again... I would repaeat this 304 times, then it should crank.
there is no buzzing at all but I know the lift pump is fueling,should I still try what you recommended. Thanks
bump the starter 3 or 4 times and it will kick in, may need to cycle it 2 or 3 times to get the air pushed out of the filter housing, should start after that
Eddie
the only thing confusing me is that I have changed that filter 20 times before,and this has never happened before
mine did the same after a filter change found that the lift pump was shot. die in between filter changes and the injector pump was doing all the sucking when i took off the cap i lost the prime
HTML:
You mean it won't start? You said crank (above) but the responses are for start failure, not crank failure!!!
Which is it so people get their responses right. .
on edit: I see you are new to TDR,, welcome to the best site ever!
