I have a 2001, and just changed the fuel filter in the same fashion I have before. I removed the filter, cleaned the housing, and filled the housing before putting the filter in. Other times I have done this it worked OK. The truck has been running just fine up until now.
Tonight I had changed oil, started the engine to check for leaks, and then did the filter. The odd thing is that it did not even try. No sign of life.
How can I fix this? Thoughts from those with experience in such circumstances would be greatly appreciated.
I have not done the fill the housing with the lift pump procedure I have seen mentioned here. How would I check to see if the lift pump could be the problem?
Do I need to open a bleeder valve somewhere, or loosen fittings? If so, is that something I can do by myself?
In some other threads I read about holding the pedal down and cranking at intervals.
Just asking a number of questions here in hopes that some folks will reply tonight.
Thank you.
Thank you.
