Miles 45,000 52,500 60,000 67,500 75,000
(Kilometers) (72 000) (84 000) (96 000) (108 000) (120 000)
[Months] [36] [42] [48] [54] [60]
Change engine oil and engine oil filter. X X X
Lubricate Front Drive Shaft Fitting (2500/3500, 4X4). X X X X X
Rotate tires. X X X X X
Lubricate outer tie rod ends 2500/3500 (4X4) models only. X X X X X
Check transfer case fluid level. X
Flush and replace engine coolant at 60 months, regardless of mileage. X
Inspect drive belts, replace as necessary. X X
Inspect water pump weep hole for blockage X X X
Replace fuel filter element. Clean the water in fuel sensor. X X X
Inspect brake linings. X X
Inspect and adjust parking brake if necessary. X X
Inspect fan hub. X
Inspect damper. X
Inspect front wheel bearings. X
It looks like they have changed the numbers around on me when I wasn't looking... ... . but it is still 60 mos
