tips
I replaced my heater core a few weeks ago and I did it without disconnecting the a/c and all. I used the NAPA heater core part number NHC 6601767. It has swiveling fittings/tubes and makes installation MUCH easier without disconnecting the a/c. Something else I found is to go to the dodge dealership and order TWO of part number 55036506-AB. Its the replacement heater core tubes WITH the bend in the end of them. NAPA and other part stores just use straight tubing that puts quite a hard bend in the end of the hose, almost a kink. I also put a shutoff valve on one side as well. I believe the advance auto parts number is either 84707 or 84706. One is a bit larger than the other, I forget which one, but I believe the 06 is the one for the 2nd gen. You can put one on both sides if you wish. Also be VERY VERY careful if your dash doesnt already have cracks in it, its VERY easy to crack. Good luck!!!!
