justinp20012500 said:I don't prefill mine, but I do pull the fuel system relay and crank for 5 full seconds to let the pump build some pressure. I also pre lube turbos this way too.
Justin
Ron Bissett said:One trick is to use old oil from the last customer with the seven year free oil change. :-laf :-laf :-laf Ron Bissett in Metro Louisville KY
rbattelle said:Cummins Troubleshooting and Repair Manual ISBe and ISB (Common Rail Fuel System) Series Engines, page 7-5, "Lubricating Oil and Filters", "Install" reads:
NOTE: Fill the filter with clean lubricating oil before installation.
Later, on page 7-13:
CAUTION
The lack of lubrication during the delay until the filter is pumped full of oil at start-up can damage the engine.
I did not add the bold, Cummins did.
For our engines, therefore, filling the oil filter is required by Cummins. Period.
-Ryan
klenger said:There are very few forum threads that have ever caused me to change my opinion about anything (and I have an opinion about everything :-laf ). This one is an exception. Ryan's post quoting the Cummins procedure sure settles the isssue in my mind. Good work.
I think I will look in the paint dept at Home Depot or Ace Hwd for some paper paint funels that have the screen in the bottom of them for prefilling the filter. Seems like this should take the risk out of contaminating the oil with anything large enough to plug an oil galley, and then just throw it away. Comments?
