Hey... I just had a great idea for the DIYers out there. Try this procedure out-
The return line is the one connected to the rear of the trans.
For best results use a translucent drain container marked in 1/2 gallon increments so that you can add to the fill tube at the same rate the bucket is filling. Installing a plug in the trans where you disconnected the line will help with any over fill condition if you dump in too much.
An even better idea would be to install a valve at that point so you could select to divert the flow to the bucket. Doing that would make it a snap to check level and drain as needed if you overfilled when done. Plus you would never have to take the line loose again. . just hook up a hose to the divert port.
Disclaimer Set the park brake
- Remove the return line at transmission
- Attach a hose to it and into a 5 gal can
- Start the truck and put in neutral
- Pump out 1 gallon and shut engine off
- Remove Pan, replace filter, install pan
- Add one gallon new fluid
- Start engine and put in neutral
- Add new fluid through the fill tube
- Use additional 3 gallons
