Okay, here goes nuthin' First time post here. I have a stock 2001 Quad Cab 2500. The short story is it started to smoke (billow) white clouds one day. Power was erratic, RPM was erratic, the whole thing would just shudder for a bit... then miraculously(?) cure itself and run fine. The dealer said it had no Boost pressure and the intercooler was shot. 56,000 *****foot miles on this rig. Some light plowing. I was told the intercooler is prone to failure from twisting and could not be repaired, must be replaced. $1300. 00 later, I have lower power, lower gas milage, and the Old Part has a 1/4 puncture wound in it that looks as if it was inflicted by a punch... hmmm. Is a 1/4 inch hole enough to causea boost problem? Wouldn't that produce rich black smoke?
The other issue was warranty work... seems the fuel booster pump had an air leak and was starving the main pump... Wouldn't that produce white smoke (aka lean)? HELP! I am considering taking this up with the AG as it seems I got hoodwinked here.
I can provide additional info as requested. I am curious as to volume of turbo flow, normal turbo boost pressure, and just how big a hole would be needed to produce" no turbo boost".
I lost about 4 mpg as a result of the repair. Dropped from 15-16 mpg ave to 12-13 mpg.
