Originally posted by Mag
Do our trucks come wired with the circuit to the plug to charge the RV's battery while the tow vehicle is running? If not ,please tell me the proper way to wire this circuit.
Thanks Greig
Originally posted by Thomas
And since the RV is connected to the Ram's batteries, the RV has the ability to discharge the Ram's batteries.
If you have the tow package. The charge line is there,all trailers are wired also. You can light your running lights by jumpering the top 2 pins in the trailer connector. Oo. Clem If not you need to run a #10 wire from the pos. side of one of the bats. through a relay that turns on when the key is in the run possion then to the trailer plug. This will keep you from killing your start batts .Originally posted by Mag
Thanks Greig
