First, my apologies for bringing up this matter once AGAIN within this forum. The questions that I raise have been discussed multiple times so I will gladly accept re-direction to appropriate threads or guidance from members.
I have owned my 1998.5, 24 valve 2500 since May 1998. I ordered it direct from the factory and have managed to put 262,000 miles on the odometer. I have had the usual problems with the VP44, accelerator pedal position sensor (APPS) and the like but I have never really solved the following issue with the charging system. I looked at the problem about 10-12 years ago but gave up since I do not have an automatic with torque converter lock-up problems and the truck pretty much started and ran.
Since the truck was close to brand new, I have experienced voltage drops when the fuel heater cycles on and off (or at least that has been the explanation given to me). The problem starts like this--if the truck has sat for maybe a week, when I get in and start the truck, I will get a "Check Gauges" light and a lower (but still above the lower tick mark) on the voltage gauge. The voltmeter will slowly rise after a short period of driving and the "Check Gauges" light will go out and the voltmeter approaches just under 14 volts. If I sit at idle, however, for any period of time, I hear what I assume to be the fuel heater cycling on and off. The volt meter will drop, the lights will dim momentarily until the fuelheater cycles off, or so I assume. It has done this for years and since it started and ran, I just lived with it.
I would like to know if there is a fix for this voltage "lag." In my mind, the alternator and electrical system should respond with the necessary voltage for truck operations. The truck is stock with few accessories except for a FASS DDRP and a fuel pressure gauge. The batteries are less than four months old and check good. The alternator is an Autolite brand from Autozone and has been in the truck probably 8-10 years (at least). I have no problems with the speedometer.
I have looked at Cummins Forum, Mopar1973Man and this forum for answers and have seen lots of information for alternator problems and torque converter issues. I will turn a wrench on this truck but I am not a mechanic and am ignorant of many electrical matters. Your guidance will be greatly appreciated.
Thanks in advance,
Mark Young
Fair Oaks, California
P.S. I do not live in an extremely cold environment but this truck spends lots of time in the snow in the Sierra Nevada mountains. You really notice the voltage drops in the colder weather.
Thanks in advance,
Mark Young
