How does $350 plus a day of work sound? I have a rental unit with a 30 year old furnace[read huge in size]. The cold air return plenum had enough room to install a 17000 BTU window unit into it . I merely cut the cold air return and installed the room side of the unit into the plenum. i also fabricated a primitive air scoop in front of the unit so it can draw relatively still air across the coil. Without the air scoop, the unit would short cycle and not do it's job, but with it , the compressor is running continuously. The thermostat has a range of 66 to 75 degrees, so I need to find the right setting for it
Just powered it up this afternoon and I will return tomorrow to see how it is working. It exhausts into a cool basement,but it would not be difficult at all to use a duct system to exhaust the hot air to the outside. I expected problems with noise and such with a telegraph effect thru the ductwork, but that is not even noticeable.
Wish me luck
Wish me luck
