Hey Guys. I am at a total loss in resolving this issue.
I am in the process of installing a BD X-Monitor (Pyro Temp. / Boost/Trans. Temp. ) system. I installed the pyro. post turbo into the elbow pipe. I installed the boost pick up tube into the forward inboard manifold bolt hole. I tapped into the cigar lighter for key on power.
I hooked up these two functions, but decided to wait to hook up the trans. temp function using a Mag-Hytec pan and 1/8 ptap sender instead of tapping into the ECM wiring as BD instructs. So, I am currently only monotoring Pyro and Boost. I programmed the readout several times to be sure this was done correctly.
My problem is that I now have a brightly lit check engine light staring back at me. I have tried to read the fault codes using the 3 key on system, the 3 acc key system, the odometer/trip meter system etc. , etc. ,etc. I have tried all of my different ignition keys to no avail. I have disconnected the batteries at least three times to try and extinguish the thing. The truck starts and runs fine. I do hear an air noise from under the dash when accelerating, but found the rubber hoses at the BD box to be intact.
I prefer not to go to the dealer to determine the cause of this issue. You guys probably have more collective knowledge than them anyway. How do I get this thing to turn off??. . Better still, what do I have to do and/buy to read the codes and reset the MIL myself???
Also, is the rushing air sound from the BD setup normal??
My truck is stock except for this gauge setup. I would like to follow through with the Mag-Hytec pan, but I am afraid I may ultimately be forced to go to the dealer for this issue and face unfounded warranty cancellation arguments.
Well what advice can you provide??
Thanks in advance, Chuck
_________________________________________________________________
2006 Laramie QC SB 4x4 48re 4. 10axle Inferno Red (3,600 miles so far)
2001 Cardinal 28ft. fiver
1969 Charger RT SE 440 Torqueflite, 3. 23 suregrip
