Archived Check engine light
Archived Jeff Egball 05 Ram no brakes
Archived Friend with a Dead 03.
I checked for the code and got P0336 which is listed as Crankshaft Position Sensor Performance.
My question is how bad is this? I was loading the truck for vacation within a hour and this just poped up this morning.
Tim
I would say it's a fairly big deal. Your truck is much newer than mine but I think some of the systems affected would be the same. On a 95, when the crankshaft sensor (called engine speed sensor on the 95's) fails, the engine will run but you have no OD, no lockup, no AC, no cruise, and no alternator charge.
It could be just connectors or ground that need to be cleaned. Sometimes a bad belt (frayed) can damage the wires to the sensor. It's easy to replace and will run between $100 (NAPA) or $150 at dealer.
