Engine/Transmission (1994 - 1998) Check engine light???
Hi, I have a CHECK ENGINE light and don't know why.
Oil pressure good
Alternator voltage good
Temperature good
Runs excellent
I didn't think there was anything that could cause it. Have never seen this before this truck is rock solid. :confused:
Never had my scanner hooked to mine but will and see what info is available if you want me to. With no ECM I would think very little if any.
Pull the code by the three on-off key strokes with the key left on, on the third stroke. Engine off of course. Count the flashes it makes.
Should be long followed by short flashes, ie 3 long 1 short =31. We can tell you what it refers to. Hooked up on mine and was able to monitor all basics, rpm, iat, ckp, etc. 260k and mine has never came on.
I'll try the flashes thing and see what it says. This has me baffled never thought a 12 valve would ever have a CEL and at 247K miles too.
Will I tried the flashy thing go no flashes? Are you pulling my leg? But, I did figure it out at first the voltage was close to 14 however it started to go down and the lights started getting dim. I hooked up a charger and the batteries charged just fine so it was the alternator. Replaced the alternator and everything works now and no CEL.
Thanks,
