Check Engine Lite
Finger Touch Oil Drain Valve
EGR cooler or head gasket?
Ok here is the deal. I am so tired of the CEL in my 2008 I am ready to remove the light from the dash so I don't have to look at it anymore. I have no problem with the truck or how it runs it is just the light and having to deal with bringing it back to the dealer all the time. Is there something out there that I can do or use to either clear the code or eliminate them totaly. I have been to the dealer for the latest flash and still don't see much differance. I also do the thing with the key on and off three times and it show no code just says "done". Thanks in advance for the help
You could go to harbor freight an buy a code reader I believe they also delete codes atleast that way you can check yourself and make sure there is no codes in computer
