Check Gage Light
Code 2609 Intake Air...
Anyone using rail caps? Pros and cons?
So I had my 03 truck in for some body work, (long story, had a Mickey Thompson Baja Claw with 8000 miles on it come apart on the the left front at 65 mph). I pick up my truck and the Check Gages light is on. All the Gauges are working normal and seem to be in the normal operating areas. Are there codes I can pull or is this something different?
Is it the CEL or check gages light?
It may have thrown a code if they had the front speed sensor unplugged while the ign was on or heck, maybe it's still unplugged.
Turn your ign on-off-on-off-on within 5 seconds and the code(s) will be displayed where you odo is.
When the tire came apart it took out the wheel well liner. It also broke the battery box and the battery temp sensor that mounts in the bottom of the batt. box. All back to normal now.
