Here is my 5th gear nut story. At 50,000 miles on my '97 I wanted to check the nut before I went on a 2,000 mi trip towing our travel trailer. I got the Dodge upgrade nut before I started. Left the trans in the truck, just pulled the transfer case and tail housing of the transmission. When I got it all apart it looked fine, the nut hadn't back off, the staking on the nut still in the keyway of the shaft. I thought, what a waste of time. When I checked the tightness of the nut there was only about 10ft lbs of torque on it. Took the nut off, looked like the threads had been "pulled". I personally don't think that the nuts simply back off, the threads are stripped and the nuts pushed off. If the nuts simply back off, the threads would not be wasted. I thought , at least I caught it in time before the gear got loose on the shaft, wrong, the gear slide right off and had been hammering on the none splined of the shaft. Since I didn't have a new gear I used Locketite 680 to secure the gear to the shaft and 277 to secure the new nut. That has been 150,000 miles ago with no problems, even with 300+ hp and towing 7,000 lbs in 5th gear.
The job is not bad, 4-6 hours of work, but I would let the Locktite cure overnight before refilling and driving. Also have a GOOD quality 10mm 12 point wrench and socket before you start, some of those bolts are TIGHT.
Bob V
