I am working on a Cummins 5. 9 swap out of a 93 250 2wd with a 5 speed. I plan on swapping the engine and trans from the dodge to the Chevy truck. I am wondering a few things. The Chevy truck has a factory tach in the dash, is there a way to make this work with the cummins engine? Also with the Vacuum pump on the cummins work well enough for the brake booster, there are no other uses for vacuum on this chassis, or should a guy get a hydroboost from a Chevy pickup or something like that? Are you guys that are doing Chevy conversions using the gear driven power steering pump and just plumbing it into the Chevy system, or are you mounting a Chevy pump on the Cummins engine? Thanks for the help.
Rich
Rich
