Hello All,
Just wanted to share some info:
Talked with Chevron and they plan to continue making the CI-4 PLUS oil for quite some time. Apparently, many fleet owners do not plan to switch to the new CJ-4 rated oil.
They now call it the DELO 400 Multigrade 15W-40 API CI-4 PLUS. Their website specifically points out that it is designed for pre-2007 diesels..... hmmmm.
Engine Oils, Synthetic Motor Oil, Delo 400 LE, SAE 15W-40 - Delo
The only catch is... . they do not sell it in gallon jugs---bulk only.
Good news though, 5 gallon buckets are available from your local distributors. If they don't have 5 gallon buckets--you can buy your own 5 gallon bucket and take it to the bulk distributor and they will fill it for you.
I just bought x2 five gallon buckets of CI-4 PLUS today for about $55 each---not bad at all.
***This is one of the "best" rated oils---per the TDR, issue 57***
This is the place I bought from: (no connections--just good family friendly service).
M. C. Herrington Chevron Distributor
11206 Airport Road
Olive Branch, Mississippi 38654
1-662-895-2210
I'm sure this place may be too far for most, but go to the Chevron Delo Performance website and click the dot on the map that is closest to your locale.
Lubricant Marketers, Diesel Fleet Owners, Diesel Lubricant – Delo
I use the 5 gallon buckets with a hand pump I bought at Northern Tool that sits in the pour hole in the bucket lid.
Anyways, regardless of the oil you choose, just thought I'd pass along this info...
Cheers.
