Engine/Transmission (1998.5 - 2002) Clarification requested on ABS
ACoyle
Super Moderator
1) I have my brake and ABS lights on. Breaks are working, ABS is not. Lights come on as soon as key is turned on. I will be checking a few things tomorrow.
2) I read about the wheel motion sensors, will also check brake switch, and fluid. Any other places to look.
3) If I get lucky and find something, I am not clear if it will reset itself when fixed to I have to have it done. In the event that I have to have it reset, has anyone out there gotten tht done anyplace, but, at the dealer.
4) If I am really lucky, is there someone in the northeast that has the tool to reset it.
Thank you
On my 99 and 02 trucks the rear wheel sensor was bad. The sensor is about 25 dollars and is cheaper than a scan. I have seen other postings for the same problem and it is usually the sensor which is mounted on top of the rear differential and easy to replace.
