Clark 5sp in a 1st Gen?
power loss
Radio problem
Clarks have a reputation for bulletproof service in medium trucks.
If they can't tear them up in a rock truck, wouldn't they offer long
term service in a CTD? I've never driven one, are there drivability
problems? Have any of you tried one? Enquiring minds...
I've heard that the clark transmission is not an overdrive. I don't know first hand but that would be a driveability issue.
Clark 5 speed
You're right Matt, that Clark trans is not an overdrive unit. I'd thought about that myself but with 4:10s, that just wouldn't work. Now if your truck is geared 3:08 or something, well now, that's a different story. For the life of me, I can't figure out why Dodge didn't gear these things to use a Clark without the overdrive crap! The design of these Getrash transmissions is insane. Who, in their right mind, would put a geared overdrive 5th gear in a diesel truck? ... ... ... ... ... Racer:confused:
There is one version that is an overdrive it is the FSO-4305, it has a . 77 in fifth and is rated at 415 lbs. ft. torque. The only thing is I don't know what bell housing to use or if it would mate to our clutch. This transmission is Mfg. by Eaton they own Clark now.
Clark's are about as big as the NV4500, I think the input shaft is larger and maybe 25lbs heavier, I've got a rebuilt 282v66 clark 5spd sitting in the garage that I don't think I'll be using now, I've got $1100 into to it... any interest... best offer:)
Luke
Here's a list of Clark Tranns I found on the net:
http://homepage.mac.com/jefe/
200V (M) 7. 58/4. 38/2. 40/1. 48/1. 00/6. 11R Clark '41-56
200VO (M) 6. 06/3. 50/1. 91/1. 00/0. 80/4. 87R Clark '41-56
202V (M) 7. 58/4. 38/3. 05/1. 72/1. 00/6. 11R Clark '41-56
204V (M) 7. 58/4. 38/3. 05/1. 72/1. 00/7. 51R Clark '41-56
204VO (M) 6. 06/3. 50/1. 80/1. 00/0. 80/6. 00R Clark '41-56
205V (M) 7. 58/4. 38/2. 40/1. 48/1. 00/7. 51R Clark '41-56
205VO (M) 6. 06/3. 50/1. 91/1. 00/0. 80/6. 00R Clark '41-56
207VO (M) 6. 06/3. 50/1. 80/1. 00/0. 86/6. 00R Clark '41-56
250V (M) 7. 08/4. 08/2. 37/1. 47/1. 00/7. 02R Clark '56-67
251VO (M) 6. 06/3. 50/1. 80/1. 00/0. 80/6. 00R Clark '56-67
259V (M) 6. 06/3. 50/2. 03/1. 18/1. 00/6. 00R Clark '56-67
264V (H) 7. 58/4. 38/3. 05/1. 72/1. 00/7. 51R Clark '53-68
264VO (H) 6. 06/3. 50/1. 80/1. 00/0. 80/6. 00R Clark '53-68
265V (H) 7. 58/4. 38/2. 40/1. 48/1. 00/7. 51R Clark '53-68
267V (H) 6. 06/3. 50/1. 80/1. 18/1. 00/6. 00R Clark '53-68
269V (H) 6. 06/3. 50/1. 91/1. 18/1. 00/6. 00R Clark '53-68
2621V (H) 7. 58/4. 10/2. 13/1. 17/1. 00/7. 20R Clark '53-68
2622V (H) 7. 08/4. 08/2. 10/1. 17/1. 00/6. 73R Clark '53-68
2651V (H) 7. 58/4. 38/2. 40/1. 48/1. 00/7. 20R Clark '53-68
2653V (H) 7. 08/4. 08/2. 23/1. 46/1. 00/6. 73R Clark '53-68
280V (H) 7. 48/4. 38/2. 40/1. 48/1. 00/6. 30R Clark '68-85 up
280VO (H) 5. 98/3. 50/1. 86/1. 00/0. 80/5. 04R Clark '68-85 up
282V (H) 6. 99/4. 09/2. 17/1. 17/1. 00/5. 89R Clark '68-85 up
285V (H) 6. 99/4. 09/2. 24/1. 46/1. 00/5. 89R Clark '68-85 up
285VHD (H) 7. 26/4. 10/2. 24/1. 26/1. 00/6. 00R Clark '68-85 up
282VHD (H) 7. 26/4. 10/2. 18/1. 37/1. 00/6. 00R Clark '68-85 up
280VOHD(H)6. 17/3. 48/1. 85/1. 00/0. 79/5. 10R Clark '68-85 up
300V (H) 7. 87/4. 41/2. 63/1. 48/1. 00/7. 87R Clark '60-68 also 310V
300VO (H) 6. 27/3. 51/1. 89/1. 00/0. 80/6. 27R Clark '60-68
301V (H) 7. 01/4. 35/2. 66/1. 63/1. 00/7. 01R Clark '60-68 also 311V
305V (H) 7. 01/3. 93/2. 34/1. 32/1. 00/7. 01R Clark '60-68 also 315V
307V (H) 6. 27/3. 51/1. 89/1. 18/1. 00/6. 27R Clark '60-68
308V (H) 7. 01/3. 92/2. 11/1. 18/1. 00/7. 01R Clark '68-75 also 318V
320V (H) 7. 87/4. 46/2. 51/1. 48/1. 00/6. 42R Clark '68-75 also 380V
380VO (H) 6. 27/3. 55/1. 89/1. 00/0. 80/5. 11R Clark '68-75
325V (H) 7. 01/3. 97/2. 34/1. 42/1. 00/5. 71R Clark '68-75 also 385V
327V (H) 6. 27/3. 55/1. 89/1. 18/1. 00/5. 11R Clark '68-75 also 387V
328V (H) 7. 01/3. 97/2. 11/1. 18/1. 00/5. 71R Clark '68-75 also 388V
390V (H) 7. 52/4. 35/2. 54/1. 52/1. 00/6. 27R Clark 76-85 also CL551
397V (H) 6. 82/3. 68/1. 99/1. 17/1. 00/5. 30R Clark 76-85 also CL557
400V (H) 7. 83/4. 52/2. 54/1. 47/1. 00/7. 63R Clark '60-75
400VO (H) 6. 17/3. 56/1. 90/1. 00/0. 80/6. 02R Clark '60-75
401V (H) 7. 07/4. 33/2. 68/1. 64/1. 00/6. 90R Clark '60-75
403V (H) 7. 83/4. 52/2. 68/1. 58/1. 00/7. 63R Clark '60-75
405V (H) 6. 17/3. 56/2. 11/1. 43/1. 00/6. 02R Clark '60-75
406V (H) 6. 61/3. 56/1. 90/1. 32/1. 00/6. 02R Clark '60-75
408V (H) 6. 17/3. 56/1. 90/1. 16/1. 00/6. 02R Clark '60-75
