Cleaner Solution
DAkota Digital FP Gauge Power
2000 versus 2002 service manual, any big difference?
Try one of those Oxygenated Powdered cleansers with hot water. The fabric on your headliner is very thin and held in place with adhesive to a rigid composite backing. If you use a cleaner that is too strong two things will happen:
1. you will remove the stains - good.
2. the adhesive holding headliner fabric to the composite will weaken and droops will develope - bad.
Scrubbing too hard will stretch the fabric as well. "Patting" is the best solution. I recommed a hair dryer to expidite the dry time, not too hot. Watch out if you use a shop vac - might suck the headliner right off when wet.
I run a automotive detail business and deal with "baby barf" and other projectiles hitting the headliner.
