I hit mine with purple power and carefully pressure washed, avoiding as many connectors as possible. I managed to smoke the under hood light bulb but everything else is fine. At least the diesel washed off.I have no water source for my garage, so I use a 2 gallon pump sprayer for water.
Usually use some of that Super Clean purple gallon and dilute in a spray bottle.
Second on hating a dirty engine compartment.I've washed EVERY engine I've ever owned EVERY time I wash the trucks... about every 2 to 3 weeks and NEVER have a problem with just the water hose with a sprayer.
I spray it down with Simple Green. They also make aerosol cans of foam engine cleaner (Gunk) works well. Get the engine warm, spray with cleaner, let set a while, and rinse. The key if using a pressure washer is keep it a couple feet away from target, dont focus too long on power distribution panel, and wiring/ connectors.
I hate working on a dirty engine and mine are always very clean.
Hope that helps some.
Cheers, Ron
I wish it was just diesel, mine was nasty and was most likely decades of stuff.If all you're trying to clean off is diesel fuel then all you need is some warm/hot water. A bucket of hot tap water or from a garden hose sitting in the sun will wash it right off. No need for harsh chemicals or pressure washers.
