CLEANING ENGINE
Usable Power Mods?
Polished stock exhaust tip *PIC*
simple green or a product like that is probably a better alternative , plus it won't start a fire if you get it on something real hot . isn't gunk something akin to kerosene ?
anywho , don't do it right after shutting down towing your 5ver and you should be fine .
plus turn off that caps lock dude , we can hear you just fine .
I used a product named Greased Lightning and an air aspirated applicator, let it set a few minutes then hosed off. Did a good job. I can't find any more of the stuff but I suspect it is similar to Simple Green, it's a household type degreaser.
Simple Green is the choice of a lot of people. It works good and won't hurt the enviroment. I have used Simple Green on everything (motorcycles,autos,oil stains and my hands). Great stuff, just don't delute it. Spray it on full strength and it works well. #ad
Bryan
Bryan De Boer
I L-O-V-E MY D-O-D-G-E
White 2000 Ram 2500 Quad s/b With a Banks Power Pack
I use simply green, works great and the cost is about $7 per gallon.
Frank
01 White, Quad Cab,Short Box ,Sport SLT+,5 speed 3. 54 Ltd-slip,4X4,line-x ,Nerf bars,fiberglass tonneau cover
If you have an Engine Brake don't forget to cover the vaccum control switch completely. If it gets any moisture into it, it tends to lock in either the off or on position.
2000 Qc LWB ETC 6Sp 3:54 LSD, + all the options except leather, BD Stage ll Injectors,Edge EZ, Psychotty& K&N,
BD E-Brake with Shifter Control, ISSPRO EGT and Boost Gauges, Transfer Flow 50 Gal. Alum. Fuel Tank, Line X
16K Hijacker Double Rocker, Pulling a 35Ft. triple slide Spinnaker 5vr.
1996 Viper GTS
Suzuki DRZ400
1100 Yamaha Cruiser
the simply green on the battery works great !
Frank
Cleaned mine yesterday with Simple Green. I put a plastic bag over the alternator to keep from getting wet. Let it sit about 5 minutes and hosed off,looks good. This was with a cold engine. I put it in neutral and pushed it out of the garage.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
