Details here: TDR Privileges
Has anyone cleaned their engine compartment yet? On a search I found most of the 2nd and 1st gen owners use Simple Green (or equivalent), then spray it down with water. Has anyone out there with an '03 tried this yet?
Simple green works good and a light blast of a hose at wash time seems to keep it from getting out of hand.
I know many people think it does damage to get every thing wet under there but I've never had any trouble with any other engines and if I ever do, it's still been well worth it.
I had to clean mine Friday night besides all the dust from summer 4x4'n in Idaho and Washington I left the drain valve open after I put in the new fuel filter:{
I could not figure out why I wasn't getting primed tell I smelled the fuel.
I used simple green and a garden hose looks and smells like it just came off the line now.
BTW my filter minder said 30% but my filter was just filthy I think 30K is stretching it on the air filter changes I think 15K is more like it.
ttreibel my filters looked as bad as yours at only 10,000 miles! I ordered the Amsoil filter today since it only costs a few more bucks than the OEM filter and is cleanable/reusable. I had one on my last truck and it was very easy to maintain and filtered extremely well the superfine dust in this area.
LOL about the drain valve trick. I see I'm not the only one who's done that one!!
For the engine and engine compartment I just use regular car wash soap and a mitt. Usually just have dust and road splash back to deal with. Simple Green works if I spill anything. I do put a rag over the alternator to keep from spraying water directly into it - just one of my quirks. I go to the coin car wash and use pre-soak and high pressure soap on the entire underside.
That fuel filter is SO dirty. I have 50,000 miles on my 01 and I think I've changed the fuel filter 4 times now. All four looked brand new, didn't really need to change them. How can that filter get that dirty that fast?
I just made an appointment to have my filter replaced at 9800 miles. I will post a picture of what it looks like.
I'm having the dealer do it, that way there's a record that the fuel filters were replaced regularly in case I need to warranty a fuel system failure at 80,000 miles!
Clue me in on the engine wash, is there going to be a big problem going to the car wash and using the high pressure washer on the engine. I'm seeing here a lot of you are spraying on the simple green and using the garden hose. All my gasser's I used the high pressure hose at the car wash, and my Cat motorgrader I use the high pressure hose on it, but it's not turbo charged.
rbattelle ... the filter changes and other maintenance are all being documented with digital photos so if there is a problem i open my laptop and show them.....
Tony T I don't see a problem with the pressure hose at the car wash just protect the electronics. My engine was just not that dirty. I only need to do that when i get motor oil all over it, the 2003 seems to be very tight still no leaks.
Not to mention if you drove it to the car wash, it's hot. Not a good thing to spray a hot engine with cold water. I don't know about the ISBe but, the B could suffer instant injector damage if sprayed with cold water on a hot engine. Throttle linkage would get it's lube washed out and electronics would get moisture in them. I "might" cringe and give the engine compartment a bath with car wash soap and a mit out in the front yard. Then lightly rinse it off with a light spray from the hose. But definately not high pressure. I don't even use high pressure on the outside or underside. I don't care much for water filled marker lights or water forced into seals underneath. I don't clean love bugs off with a hammer either!
The detail shop I am familiar with uses straight Purple Power (get it at Advance Auto Parts for about $7. 50 for 2. 5 gals) and a standard garden hose for cleaning engine compartments. They've been in business for several years and never had any problems and the stuff works great. They do start with a COLD engine - spray it when it's off, start it up then hose it down right away.
Over the years in the auto repair business I had some BIG parts tickets due to high pressure spray. Shorted distubotors and ecm's etc. not to mention one's that drove a few hundred feet and died due to water filled connectors etc.
Castrol Super Clean in a garden sprayer (so I can spray up under the truck or whereever) and the garden hose as long as I have been driving (no age jokes here guys! I'm young, you're jealous! ) every time I wash. Works great, never had a problem, and techs love to work on a clean engine. IMO, the techs at the dealer are more likely to do a better job on a truck that is nice and clean and taken care of than a truck with 50,000 miles of crud on it. Just a thought.
When clean, as in brand new, I get a can or two of WD40 or equivalent and spray the wire's harness inside fuse box etc. I coat the battery terminals with grease so moisture will not get in there. then I'll clean the engine with soap and water. I was told that simple green while very effective on grease and oil may dis color aluminum. wheel cleaner is usually a better alternative for tough spots.
