Is there a way to clear ABS fault codes (#65-main relay open) without a scan tool? Unfortunately :{ I have the optional 4 wheel ABS, which is much harder to diagnose and get parts for. On the standard RWAL system I've seen posted that you ground a particular plug terminal. I can't find out if that's true for the 4 wheel system. ideas?
