Sno'd King, I took my truck to a large gravel parking lot today and did some testing to see if I could find the cause of the clicking noise that seems be in the steering. Driving slowly, I positioned the steering wheel into a moderate right turn and could make it do the clicking sound at will. I stopped, then rocked the truck back and forth and I could make it do it when I held just the right amount of steering pressure on the steering wheel. I then attached my Gopro camera in several locations capturing the operation of most of the steering parts and suspension parts (tie rod ends, track rod ends, pitman arm, steering shaft at steering box, and steering shaft coming from column.
After viewing the video everything looked good, except the steering shaft coming out of the steering column. You could see side to side movement at the end of the shaft just beyond the compression spring. The movement is sudden and it appears match the timing of the symptoms - too much engine noise under the hood for the camera to pick up the clicking sound.
I ordered the Rock Solid replacement bushing kit today. I will let you know if the repair fixes the problem.
John
