Close up photos of PSD valvetrain
Dodge's New V-10 Diesel
Ways to make money with a Dodge Diesel?
The Rocker Arms Look like...
... those cheesey stamped steel wrenches the Japs put in their motorcycle tool kits back in the sixties and seventies.
OH My god. . did the ford engineers cut them out of an old stop sign , are they at least supported on some sort of roller or bearing
:confused: :confused: :confused: :confused: :confused: :confused:
It ain't easy bein' cheesy...
Yeah,the rockers sure aren't made of much. I had the valve covers off of our 97 at work(replacing glow plugs:rolleyes: )and couldn't believe those whimpy looking things:eek: . Doug
My uncle showed me some at his shop that had gotten bent due to overrev, jumping down too low a gear downgrade. A couple of push rods were bent also.
What's so funny about the link is there was only one bid for $100 ROTFLMAO!!:D
This is from Steves write up on the new 2003 motor, but I believe the valve train is the same - the ISB's dont have those fancy and expensive hardwired injectors like this picture shows.
Considering the redline of the powerstroke and the design of these particular rockers, they actually look pretty strong to me...
although i will agree they look "cheap"
They redline about the same as a Cummins if I remember correctly - 3500 rpm. I'm not an engineer, and I'll admit they might be stronger than they look - but they still look cheap. My old 6. 2 chebby had cast steel rockers with brass or oilite bushings and that was not a good motor. I'm wondering what the guts of a Duradud look like.
Just remember that the bending moment of inertia is a function of the width times the height^3. If you make it taller it gets a lot stronger. It's the same idea behind an I-beam, and why drive shafts are hollow. I agree that they do look flimsy, but they are actually quite tall and strong enough for the loading placed on them.
They don't look all that flimsy... of course I used to be a foreign car mechanic. Ever seen the head off of a Fiat 1600 pushrod engine??
If I remember from my strength of materials classes... .
The Moment of Inertia (I) is a term used to describe the capacity of a cross-section to resist bending. It is always considered with respect to a reference axis such as X-X or Y-Y. It is a mathematical property of a section concerned with a surface area and how that area is distributed about the reference axis. The reference axis is usually a centroidal axis.
The moment of inertia is also known as the Second Moment of the Area and is expressed mathematically as:
Ixx = Sum (A)(y2)
In which:
Ixx = the moment of inertia around the x axis
A = the area of the plane of the object
y = the distance between the centroid of the object and the x axis
The 24V motor doesn't look to much better under the cover. There is a huge cast iron rocker arm that goes to a spindly little triangle thing that allows the massive rocker arm to open 2 valves at once.
Clark
