Clunking noise from front end
100K tips
best year
Wow I was sure it would be too... . hmmm does it clunk when you hit bumps or on any surface? you have new shocks the other thing I can think of is bad ball joints but thats a long shot... ..... My 2 cents would be replace those bushing its a cheap guess... .....
A noise like what? can you feel the clunking in the steering wheel?How about have you raised your truck and checked hubs for play?.....
Just raise the truck and check for excessive movement in the bearing basically grab the tire and move back and forth see if theres too much play.
Check the track bar too. Could be loose or have a bad bushing(s).
Might also want to try removing the steering stabilizer temporarily and see if the noise disappears.
Ryan
Sway bar
Be sure you check your sway bar bushing links and and sway bar frame mounting bushings. my sway bar frame bushings were wore and it made a god awful clunking when going down a bumpy road. I put some urethane ones in no more noise... .
I guess I didnt check the sway bar bushing links good enought, when I hit the right side with my hand it made the clunking noise. So I need some new ones, any body know of a good place to get some. I checked Orylies the will have to order some for $ 101. 98, that is for both sides. Lifetime warranty. :-laf
ouch for just the links... ... . try ebay Im looking at some as we speak because I broke one I they are asking 39 bux
